[Nagios-devel] Nagios/CVS HEAD compilation issues on Solaris (strsep patch)
Nagios/CVS HEAD already has a configure script, so I ran that and it
completed fine. But compilation fails, complaining about symbols that
are part of Nagios.
gcc -g -O2 -I/opt/imagelib/include -DHAVE_CONFIG_H -DNSCORE -o nagios nagios.c broker.o nebmods.o checks.o config.o commands.o events.o flapping.o logging.o notifications.o sehandlers.o utils.o retention-base.o xretention-base.o comments-base.o xcomments-base.o objects-base.o xobjects-base.o statusdata-base.o xstatusdata-base.o perfdata-base.o xperfdata-base.o downtime-base.o xdowntime-base.o -L/opt/imagelib/lib -lm -lnsl -lsocket -lpthread -ldl
Undefined first referenced
symbol in file
strsep xretention-base.o
nanosleep events.o
ld: fatal: Symbol referencing errors. No output written to nagios
collect2: ld returned 1 exit status
First, in every file except for the x?ddefaults.c files you replaced
strsep() with my_strsep(). This patch brings these two together:
*** xdata/xrddefault.c_orig Sat Nov 22 13:36:18 2003
--- xdata/xrddefault.c Sat Nov 22 13:36:56 2003
*** 633,639 ****
else if(!strcmp(var,"state_history")){
temp_ptr=val;
for(x=0;xstate_history[x]=atoi(strsep(&temp_ptr,","));
temp_host->state_history_index=0;
--- 633,639 ----
temp_ptr=val;
for(x=0;xstate_history[x]=atoi(my_strsep(&temp_ptr,","));
*** 796,802 ****
temp_ptr=val;
temp_service->state_history_index=0;
--- 796,802 ----
temp_ptr=val;
*** xdata/xsddefault.c_orig Sat Nov 22 13:36:31 2003
--- xdata/xsddefault.c Sat Nov 22 13:37:06 2003
*** 650,656 ****
temp_ptr=val;
temp_hoststatus->state_history_index=0;
--- 650,656 ----
temp_ptr=val;
*** 743,749 ****
temp_ptr=val;
temp_servicestatus->state_history_index=0;
--- 743,749 ----
temp_ptr=val;
To get nanosleep on Solaris, so you have to link with -lposix4.
This should be tested for by autoconf
Joe Rhett Chief Geek
[email protected] Isite Services, Inc.
