Re: [Nagios-devel] [PATCH] fix datarootdir warnings by autoconf 2.61
Hendrik Baecker wrote:
> Andreas Ericsson schrieb:
>> Ton Voon wrote:
>>> Hi Hendrik,
>>> On 30 May 2009, at 20:39, Hendrik Baecker wrote:
>>>> After upgrading from autoconf 2.59 to 2.61 a new
>>>> option was givven: --datarootdir
>>>> The datarootdir replaces the old htmldir/datadir in
>>>> subst.in and Makefile.in files.
>>>> This patch fixes some minor makefile cleanups for the new t-tap
>>>> directory. A 'make distclean' will result in a really clean
>>>> directory.
>>> I've applied the t-tap cleanups - thanks.
>>> I haven't applied the datarootdir option. I'm not sure what we are
>>> doing regarding autoconf and other dev tools.
>>> Ethan, Andreas, any thoughts? For the plugins, we list the developer
>>> requirements and we do not commit any files that are auto generated.
>> I agree 100% with not committing autogenerated files. Such files should
>> ofcourse be included in releases, but having them in the repo is just so
>> much dead weight.
> So you want one extra step for those guys who are dealing with the
> latest head?
> IMO the change frequency of autogenerated files like configure isn't
> too high to save larger commit diffs caused by this fileclass.
> Where do you see a problem after changing some code which needs an
> update of the configure.in stuff to rebuild configure by the developer
> and check this in?
> As long all dev members are using the same autoconf version I don't
> see a big problem.
> Is it safer to don't commit those file for the development process?
> Hendrik
The only thing anyone should be mucking with when making changes is
configure.in. The "configure" script has been in CVS for ages, and
there's no reason to take it out now. I don't really think there's an
absolute requirement that all the core devs use the same autoconf
version, as long as its somewhat recent. Makes it a hell of a lot
easier to just to a CVS checkout and run ./configure, which helps with
automated scripts.
- Ethan Galstad
