Re: [Nagios-devel] NSCA bottleneck / NSCA Timestamp
Hi Thomas,
> While I don't have the final word, I really think this would be a good
> idea. I think the best would be to keep full backwards-compatibility
> while having an additional send_nsca switch to enable timestamps (would
> add a required "[TAB]" in front of the other arguments passed
> via STDIN). A compatible NSCA server would detect the timestamp (Not
> sure how data in transfered, so I'll leave specific implementation
> details to you) and use it for Nagios processing.
I would alter both client (send_nsca) and the daemon itself (nsca). I am
thinking of a simple "-t" like "cat host-results | send_nsca -t -H
foo.bar -c ...=20
> On a side note, you can have near-realtime processing without much
> overhead with the Perl OCP_Daemon I wrote:
>=20
> http://www.nagioscommunity.org/wiki/ind ... OCP_Daemon
Hm, I know it but I think there is no need for it. As mentioned above I
am using the same nagios config parameters than you. But I am using a
simple flat file with the "a" option. And with the help of the
host_perfdata_file_processiong_interval and the
host_perfdata_file_processiong_command I send this over via send_nsca.
Cheers,
Gerd
> Thomas
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.7 (MingW32)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
>=20
> iD8DBQFHQdH96dZ+Kt5BchYRApNYAJ4hKLWXs7tkYk7105KNnGa9dJaEAQCggCgP
> L65PyPgFgmMOEjpwhd1NjJ4=3D
> =3DdnXt
> -----END PGP SIGNATURE-----
>=20
> This SF.net email is sponsored by: Microsoft
> Defy all challenges. Microsoft(R) Visual Studio 2005.
> http://clk.atdmt.com/MRT/go/vse0120000070mrt/direct/01/
> Nagios-devel mailing list
> [email protected]
--=20
Gerd Mueller =20
Senior Consultant
NETWAYS GmbH | Deutschherrnstr. 47a | D-90429 N=FCrnberg=20
Tel: +49 911 92885-0 | Fax: +49 911 92885-33=20
GF: Julian Hein | AG N=FCrnberg HRB18461=20
=20
http://www.netways.de | [email protected]=20
