Re: [Nagios-devel] nagios-cvs: reload/restart
> 1. Does the web interface say that external commands are disabled?
I am not sure if it's really the external commands Nagios or it's just
the logging. I could send an external command via the webinterface but
did not check the process info. But anyway no entry about external
commands does appear inside the logfie.
> 2. Don't delete the retention file right away. The program{} entry at
> the beginning of the file should contain information needed to debug
> this problem. Perhaps something is happening that is causing Nagios to
> write the incorrect values to the retention file, thus disabling
> external commands when it reads from the file after it restarts.
I won't do this anymore :-). This morning we run into a situation where
the master server (the nsca receiver) was'nt able to fork any process
anymore. BTW is the version string always up to date? Because I got the
source Wednesday out of the cvs?
info {
created=1172172211
version=3.0prealpha-02082007
program {
modified_host_attributes=0
modified_service_attributes=0
enable_notifications=1
active_service_checks_enabled=1
passive_service_checks_enabled=1
active_host_checks_enabled=1
passive_host_checks_enabled=1
enable_event_handlers=1
obsess_over_services=0
obsess_over_hosts=0
check_service_freshness=1
check_host_freshness=0
enable_flap_detection=0
enable_failure_prediction=1
process_performance_data=1
global_host_event_handler=
global_service_event_handler=
next_comment_id=1
next_downtime_id=1
next_event_id=3857
next_notification_id=371
> I just wrote a script that restarted Nagios 100 times using an external
> command, and submitted a passive check after each restart. Nagios came
> through okay, so the problem will take a bit of work to fix.
Hm, please keep in mind that we only use passiv hosts (~3500) and
service on this machine. Could this be a cause of these problems?
Gerd
