--------------040302040706090604090104
Content-Type: text/plain; charset=us-ascii; format=flowed
It would also be nice if
--enable-command-args
is added also to the config section to show this feature.
Can be disabled by simply commenting out if desired.
Here is the related diff -ru that also includes the already reported
corrections:
[root@arion SPECS]# diff -ru nrpe-2.2.spec ../BUILD/nrpe-2.2/nrpe.spec
--- nrpe-2.2.spec 2006-01-23 15:48:07.000000000 +0200
+++ ../BUILD/nrpe-2.2/nrpe.spec 2006-01-21 03:03:22.000000000 +0200
@@ -1,6 +1,6 @@
%define name nrpe
%define version 2.2
-%define release 1
+%define release 1
%define nsusr nagios
%define nsgrp nagios
%define nsport 5666
@@ -17,8 +17,7 @@
Version: %{version}
Release: %{release}
-# Copyright: GPL
-License: GPL
+Copyright: GPL
Group: Application/System
Source0: %{name}-%{version}.tar.gz
BuildRoot: %{_tmppath}/%{name}-buildroot
@@ -110,8 +109,7 @@
--libexecdir=%{_prefix}/lib/nagios/plugins \
--datadir=%{_prefix}/share/nagios \
--sysconfdir=/etc/nagios \
- --localstatedir=/var/log/nagios \
- --enable-command-args
+ --localstatedir=/var/log/nagios
make all
@@ -123,7 +121,7 @@
install -d -m 0755 ${RPM_BUILD_ROOT}/usr/lib/nagios/plugins
# install templated configuration files
-cp sample-config/nrpe.cfg ${RPM_BUILD_ROOT}/etc/nagios/nrpe.cfg
+cp nrpe.cfg ${RPM_BUILD_ROOT}/etc/nagios/nrpe.cfg
cp init-script ${RPM_BUILD_ROOT}/etc/init.d/nrpe
cp src/nrpe ${RPM_BUILD_ROOT}/usr/sbin
cp src/check_nrpe ${RPM_BUILD_ROOT}/usr/lib/nagios/plugins
@@ -149,12 +147,6 @@
%doc Changelog LEGAL README
%changelog
-* Mon Jan 23 2006 Andreas Kasenides ankcs.ucy.ac.cy
-- fixed nrpe.cfg relocation to sample-config
-- replaced Copyright label with License
-- added --enable-command-args to enable remote arg passing
- (if desired can be disabled by commenting out)
* Wed Nov 12 2003 Ingimar Robertsson
- Added adding of nagios group if it does not exist.
Ethan Galstad wrote:
>Thanks! Will be in CVS shortly...
>On 22 Jan 2006 at 19:21, John Berninger wrote:
>>I pulled down the plugins in $subject that were dates Jan 21, 2006, and
>>discovered that they wouldn't build due to incorrect specfiles. The
>>changes required were fairly trivial; I also had to add the LICENSE file
>>to the NSCA plugin tarball, which isn't reflected in the attached
>>patches. Using specfiles with these patches, I was able to build both
>>plugins normally on a Fedora Core 3 system.
>>John
>Ethan Galstad,
>Nagios Developer
>Email: [email protected]
>Website: http://www.nagios.org
>This SF.net email is sponsored by: Splunk Inc. Do you grep through log files
>for problems? Stop! Download the new AJAX search engine that makes
>searching your log files as easy as surfing the web. DOWNLOAD SPLUNK!
>http://sel.as-us.falkag.net/sel?cmd=lnk ... dat=121642
>_______________________________________________
>Nagios-devel mailing list
>[email protected]
>https://lists.sourceforge.net/lists/lis ... gios-devel
Andreas Kasenides
Tel: +357 - 22892714
e-mail: Andreas.Kasenides%at%cs.ucy.ac.cy
(replace the %at% above with @)
Content-Type: text/html; charset=us-ascii
co
...[email truncated]...
