--------------040606040106080305020901
Hi all,
The external command DISABLE_CONTACTGROUP_SVC_NOTIFICATIONS seems to not
work properly.
Attached is a patch that fixes the bug.
Mathieu
name="patch-disable-contactgroup-svc-notifications.txt"
Content-Disposition: inline;
filename="patch-disable-contactgroup-svc-notifications.txt"
--- nagios-3.0.1/base/commands.c 2008-04-28 18:02:10.000000000 -0400
+++ nagios-3.0.1-original/base/commands.c 2008-04-28 18:01:20.000000000 -0400
@@ -3770,7 +3770,7 @@
unsigned long attr=MODATTR_NOTIFICATIONS_ENABLED;
/* no change */
- if(cntct->service_notifications_enabled==FALSE)
+ if(cntct->service_notifications_enabled==TRUE)
return;
/* set the attribute modified flag */
--------------040606040106080305020901--
