Re: [Nagios-devel] coredumps
Andreas Ericsson wrote:
> I know. I wrote that code in order to be able to run nagios
> in a debugging
> setup. I'm not complaining about changing it, I'm just very
> reluctant about
> not having a quick and easy way to override a setting that
> only root can
> change, and especially so when the option I want to override
> only has impact
> on debugging. Hence my suggestion to make this a config
> variable, preferrably
> overridable with a command-line option.
One more thing: user can't change his home directory,
so using passwd entry is reasonably safe.
With best regards,
Andrew.
