Re: [Nagios-devel] May be a bug when using wildcards in some =
well, today I tested with the new stable 2.0 version, and the problem =
persists.
take a look, with this config:
define serviceescalation{
hostgroup_name pt.c.*
service_description a*
first_notification 4
last_notification 0
notification_interval 30
contact_groups pt.c.it.systems
with a* it accepts all services:
Checking services...
Checked 1551 services.
Checking service escalations...
Checked 1551 service escalations.
by now i will use this primitive solution.
Is there any bug tracking system to submit the bug? How developers can =
aknowledge this bug?
thank you a lot
helder
-----Original Message-----
Sent: Fri 2/10/2006 11:57 AM
To: Estagiario TI Compal
Cc: [email protected]
Subject: Re: [Nagios-devel] May be a bug when using wildcards in some =
directives in serviceescalations definition
=20
Estagiario TI Compal wrote:
> Im running Nagios 2.0rc1.
>=20
Then the first step is to try upgrading to the latest version. Nagios=20
2.0 was released as stable a week or two back, so you should be using=20
that. rc1 is at least a couple of months old.
--=20
OP5 AB www.op5.se
Original poster: ndreas Ericsson [mailto:[email protected]
