Re: [Nagios-devel] fix request
Christian Schneemann schrieb am Thursday, den 13. August 2009:
> On Wednesday August 12 2009 08:05:54 pm Roy Sigurd Karlsbakk wrote:
> > hi
> > the nagios/cgi-bin/statuswml.cgi?ping=1%3Bcat+%2Fetc%2Fpasswd bug
> > isn't fixed in nagios 3.0. Will that be done, or must I upgrade to 3.1?
> Hi,
> I had to extract the fix for our openSUSE 11.1 package, it is not a big patch
> and just the statuswml.c is affected.
> If you're running a openSUSE or a SLES you should already got a patched
> version, don't know for other distributions, but I think so too.
> If you have installed from source, poor you ;)
> I can send you the patch off list if you want. Or you make a diff of
> statuswml.c of a fixed version and the 3.0.6.
The bug is also fixed in Debian. See my patch here:
http://svn.debian.org/wsvn/pkg-nagios/n ... 543.dpatch
Alex
