Re: [Nagios-devel] Nagios 3 - Documentation Quickstart Ubuntu
Hendrik Bäcker wrote:
> Hi Ethan,
> hi list,
> on the Quickstart Ubuntu Guide there is a mentioned requirement for the
> gd libs like:
> "sudo apt-get install libgd2-dev"
> on an actual Ubuntu 7.10 it should looks like this:
> "sudo apt-get install libgd2-noxpm-dev"
> perhaps the package "libgd2-noxpm" is necessary too.
> Regards,
> Hendrik
Thanks Hendrik - I'll update the docs. Someone mentioned using the
"libgd2-xpm-dev" library, instead of the "noxpm" library. xpm isn't
required for Nagios, but people might need it for something else.
Ethan Galstad
Nagios Developer
___
Email: [email protected]
Web: www.nagios.org
