Hi to all,
I'm sorry for the mistakes, and for nosie, I reconfigured and recompiled with
./configure --with-template-objects
make all
make install
but is not clear form documentation supplied.
Also I discoverd that template-objects can't work together with old style
definitions.
massimiliano balsamo wrote:
> Hi paul,
> I don't think is the same,leaving the main config file as it is, I changed
> only inside host definition, just the definition of the 24x7 timeperiod (the
> beginning of host.cfg follows):
> # '24x7' timeperiod definition
> define timeperiod{
> name 24x7; The 'name' of this timperiod definition - can be used for template
> recursion/resolution
> timeperiod_name 24x7 ; The name of this timperiod, as used/recognized
> byNagios alias 24 Hours A Day, 7 Days A Week
> sunday 00:00-24:00
> monday 00:00-24:00
> tuesday 00:00-24:00
> wednesday 00:00-24:00
> thursday 00:00-24:00
> friday 00:00-24:00
> saturday 00:00-24:00
> #timeperiod[24x7]=24 Hours A Day, 7 Days
> #A Week;00:00-24:00;00:00-24:00;00:00-24:00;00:00-24:00;00:00-24:00;00
> #:00-24:00;00:00-24:00
> As you suggested I changed tab chars to single space.
> Nagios 1.0a0
> Copyright (c) 1999-2001 Ethan Galstad ([email protected])
> Last Modified: 10-31-2001
> License: GPL
> Reading configuration data...
> Error in host configuration file '/usr/local/nagios/etc/hosts.cfg' - Line 2
> (Could not parse input)
> first line is right !!! And is a different error from yours
> Massimiliano.
> [email protected] wrote:
> > Hi Massimiliano,
> > I've had similar problem with the config files. This could be caused by a
> > between the define and spaces after the '{'
> > My messages were like 'illegal character on line '
> > Might be the same case ?
> > hth
> > regards
> > paul
> > *speaking for himself
> > I started to convert old config files, and rebuilding in the new
> > template definition style
> > but I was surprised that every line begging with
> > define command{
> > define timeperiod{
> > define host{
> > and so ... generates the following
> > Error ..... ..... .... (Could not parse input)
> > (dots stays for config file and line number containing define directive)
> > Is template based system described and still not working in this
> > release or do I miss something in the configuration/building of nagios ?
> Massimiliano Balsamo
> CSA
> www.securegroup.it
> Nagios-devel mailing list
> [email protected]
CSA
www.securegroup.it
