Content-Type: text/plain; charset=UTF-8
On Thu, Oct 1, 2009 at 09:02, Ton Voon wrote:
> Hi Allan,
> On 30 Sep 2009, at 00:58, Allan Clark wrote:
> CVS delta 1.147 -> 1.148 includes un-dnl-ing some AC_CHECK_LIBS for
> USL/SVR4 -derivative Unix environments.
> Note that the act of CHECK_LIBS (main) -- which is used to avoid having t=
o
> give an entry point/label -- is also replaced by the actual name of an en=
try
> point.
> For details, see also:
> http://www.gnu.org/software/autoconf/ma ... aries.html
> The following change converts this Solaris edit to a SEARCH rather than a
> CHECK, which works on all platforms, and only adds additional librarires =
if
> the mentioned linker entry points are not already valid in the current li=
st
> of libraries:
> --- configure.in.solaris 2009-09-30 00:48:17.000000000 +0100
> +++ configure.in 2009-09-30 00:51:37.000000000 +0100
> @@ -101,9 +101,8 @@
> dnl Checks for library functions.
> -AC_CHECK_LIB(nsl,main,SOCKETLIBS=3D"$SOCKETLIBS -lnsl")
> -AC_CHECK_LIB(socket,socket,SOCKETLIBS=3D"$SOCKETLIBS -lsocket")
> -AC_SUBST(SOCKETLIBS)
> +AC_SEARCH_LIBS([getservbyname],[nsl])
> +AC_SEARCH_LIBS([connect],[socket])
> AC_CHECK_FUNCS(initgroups setenv strdup strstr strtoul unsetenv)
> AC_MSG_CHECKING(for type of socket size)
> Note: this also drops the need for "SOCKETLIBS" tracking. Libs add the n=
sl
> (NameServices lib) and socket (yeah, socket) libraries only if the
> pre-existing libraries (libc, libC, et al) don't already provde the lib.
> This check is really intended for the merge-point where sockets moved fro=
m
> being environmental things to in-kernel things, and not all executables
> wanted to link with sockets included by default.
> Good point re: AC_SEARCH_LIBS rather than AC_CHECK_LIB, and good point re=
> checking for actual functions.
> However, I would still want SOCKETLIBS to be set otherwise the libraries
> will get linked to other parts of Nagios that do not need it, like CGIs a=
nd
> nagiostats. So I propose:
> +AC_SEARCH_LIBS([getservbyname],[nsl],[SOCKETLIBS=3D"$SOCKETLIBS -lnsl"])
> +AC_SEARCH_LIBS([connect],[socket],[SOCKETLIBS=3D"$SOCKETLIBS -lsocket"])
> Comments?
Makes sense... still accomplishes the objective of my suggestion
(my vote: go for it)
Allan
--=20
http://tech.chickenandporn.com/tags/nagios/ "=E9=87=91=E9=B1=BC"
http://linkedin.com/in/goldfishSent from London, Eng, United Kingdom
--0016e64611cc0bd8800474e48881
Content-Type: text/html; charset=UTF-8
On Thu, Oct 1, 2009 at 09:02, Ton Voon <[email protected]=
> wrote:
Hi Allan,On 30 Sep 2009, at 00:58, Allan Clark wrote:CVS delta 1.147 -> 1.148 includes un-dnl-ing some AC_CH=
ECK_LIBS for USL/SVR4 -derivative Unix environments.
Note that the act of CHECK_LIBS (main) -- which is used=
to avoid having to give an entry point/label -- is also replaced by the ac=
tual name of an entry point. For details, see als=
o:
http://www.gnu.org/software/aut=
oconf/manual/html_node/Libraries.html
The following change converts this Solaris edit to a SEARCH rather tha=
n a CHECK, which works on all platforms,
...[email truncated]...
