Joe Pruett wrote:
>>My remembrance of the setup documentation is that you add your web
>>server user to the nagioscmd group, not run the web server with the gid
>>of nagioscmd. They're very different and firmly based on standard unix
>>permission methodology. Actually quoting from the doccos --
>>"Next we're going to create a new group whose members include the user
>>the web server is running as and the user Nagios is running as. Let's
>>say we call this new group 'nagiocmd' (you can name it differently if
>>you wish). On RedHat Linux you can use the following command to add a
>>new group (other systems may differ):
>>/usr/sbin/groupadd nagiocmd
>>Next, add the web server user (nobody or apache, etc) and the Nagios
>>user (nagios) to the newly created group with the following commands:
>>/usr/sbin/usermod -G nagiocmd nagios
>>/usr/sbin/usermod -G nagiocmd nobody"
>> -- http://nagios.sourceforge.net/docs/2_0/commandfile.html --
>>There is nothing that says run the web server as gid nagioscmd.
> if the web server isn't running with that gid in its effective list, it
> does no good. that is why you have to restart the server to pick up that
> new gid.
> i now see the comment at the top of the faq indicating that using cgiwrap
> is recommended for multi user machines. i'm still curious about nagios
> having its own auth mechanism to help with this problem (and others as
> well since .htaccess auth isn't the best method).
With single-site and SSL it's never been disputed as insecure. However,
I'm working on a PHP API (and a rough gui) which will indeed include
authentication mechanisms.
> The SF.Net email is sponsored by: Beat the post-holiday blues
> Get a FREE limited edition SourceForge.net t-shirt from ThinkGeek.
> It's fun and FREE -- well, almost....http://www.thinkgeek.com/sfshirt
> Nagios-devel mailing list
> [email protected]
OP5 AB www.op5.se
Lead Developer
