3d status map not working
shantanu
Post by shantanu »
hi! This is Shantanu from India.
I have just configured nagios core 3.0 but after integrating arana addons, the 3d status map is going black. Does any body know where is the problem....
guess is somewhere in the the .js script!!!!
Thanks in advance....
mguthrie
Re: 3d status map not working
Post by mguthrie »
We haven't messed with the arana theme much, we're started incorporating exfoliation as the default them into Nagios Core. Are you getting any useful messages in your apache error log?
If it's a javascript error, you'll have to use the "Error Console" in your browser to see what the problem is since javascript is client-side. I would try contacting the Arana developer as well, he might be able to find the solution quicker than we can.
shantanu
Post by shantanu »
Thanks for your response. Please keep me informed if anything turns up..
Appreciate it..
rdedon
Post by rdedon »
Here would be the info to contact him directly:
http://sourceforge.net/project/memberli ... _id=345577
Rene deDon
Technical Team
___
Nagios Enterprises, LLC
Web: http://www.nagios.com
