--=-DiNWWzNczcWUjXzJRQms
Content-Type: multipart/mixed; boundary="=-TtKMkkAMJWxPPNq/8tKa"
--=-TtKMkkAMJWxPPNq/8tKa
Content-Type: text/plain
I found I had a bug in the spec I previously sent, I used a wrong
directory to fetch sample httpd.conf.
Also, running the init script, I found that it was needed to touch &
chown /var/run/nagios.pid to be able to start nagios.
The attached patch fixes both problems against HEAD.
Regards, Rui
--=20
+ No matter how much you do, you never do enough -- unknown
+ Whatever you do will be insignificant,
| but it is very important that you do it -- Gandhi
+ So let's do it...?
Please AVOID sending me WORD, EXCEL or POWERPOINT attachments.
See http://www.fsf.org/philosophy/no-word-attachments.html
Content-Disposition: attachment; filename=fix-rh-spec+init.diff
Content-Type: text/x-patch; name=fix-rh-spec+init.diff; charset=UTF-8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=
--=-TtKMkkAMJWxPPNq/8tKa--
Content-Type: application/pgp-signature; name=signature.asc
Content-Description: This is a digitally signed message part
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.0 (GNU/Linux)
iD8DBQBB+Qvro+C50no0+t4RAqhAAJ9C0lKOG2IHhyoeg9KX8ZtB9FVsdACeJgIq
HL5nyAYS2YX33cHULdDrmo8=
=nDpj
-----END PGP SIGNATURE-----
--=-DiNWWzNczcWUjXzJRQms--
