Re: [Nagios-devel] Nagios 4 ignores object_cache_file and log_file
Am 16.09.2012 um 23:32 schrieb Andreas Ericsson :
> On 09/16/2012 05:13 PM, Joerg Linge wrote:
>>=20
>> Am 16.09.2012 um 16:27 schrieb Andreas Ericsson :
>>>=20
>>> Well, that's by design. The objects.cache should only be written to =
once.
>>> Or do you mean that it gets created but is empty?
>>=20
>> Correct.
>> object_cache_file was created using the wrong path =
(/usr/local/nagios/var/objects.cache as defined in includes/locations.h =
instead of /omd/sites/ng4/var/nagios/objects.cache defined in nagios.cfg =
>>=20
>> But the file contains just the header.
>>=20
>=20
> Righto. I figured it out and a fix is pushed to both github and to
> svn. Thanks for helping out.
pulled and tested!
Thanks Andreas. Now it works
Cheers
Joerg=
