There is a bug in Nagios 3.0a4, utils.c, function process_check_result_file.
It's impossible to process result list having more then one result output.
eg. submitting many service checks in one moment causes creating temporary
file (in /usr/local/nagios/var/spool/checkresults) which contains several
records divided by '\n'. Function process_check_result_file which process
this file is looking for a '\x0' as a record divider, but there is no such
line.
Result: function process_check_result_file returns only one last record in
file.
Remedy: replace '\x0' for '\n' in:
/* whitespace indicates end of record */
else if(input[0]=='\x0'){
It should work fine, it's working for me
I'm not familiar with nagios architecture, maybe there is other solution for
this problem (putting whitespace between records? maybe?).
have fun
Roman Trylski
