Re: [Nagios-devel] Max concurrent checks - spreading the next_time
Ton Voon wrote:
> Hi!
> We've seen situations where this appears in the nagios.log:
> Max concurrent service checks (50) has been reached. Delaying further
> checks until previous checks are complete...
> When switching on debugging, what we noticed is that services are
> invoked all around the same time. I guess this happens when you have
> selected a host and say "force check all services on this host".
> What happens is that in the event code (base/events.c), it seems that if
> this max_concurrent_checks is reached, then the service is ignored and
> is rescheduled with a next check time based on the next regular check
> interval. But if you do that, then all the other services will still be
> invoked around the same time.
> /* reschedule the check if we can't run it now */
> if(run_event==FALSE){
> /* remove the service check from the event queue and reschedule it
> for a later time */
> /* 12/20/05 since event was not executed, it needs to be remove()'ed
> to maintain sync with event broker modules */
> temp_event=event_list_low;
> remove_event(temp_event,&event_list_low,&event_list_low_tail);
> if(temp_service->state_type==SOFT_STATE &&
> temp_service->current_state!=STATE_OK)
> temp_service->next_check=(time_t)(temp_service->next_check+(temp_service->retry_interval*interval_length));
> else
> temp_service->next_check=(time_t)(temp_service->next_check+(temp_service->check_interval*interval_length));
> temp_event->run_time=temp_service->next_check;
> reschedule_event(temp_event,&event_list_low,&event_list_low_tail);
> update_service_status(temp_service,FALSE);
> run_event=FALSE;
> I propose that instead of setting next_time = next_time +
> check_interval, that there is a random factor added, maybe something like:
> next_time = now + max(5, min(int(rand(15)),
> int(rand(retry_interval*interval_length))))
> This means that the next check has been moved at least 5 seconds away
> from now (to overcome the temporary load due to the number of concurrent
> service checks), with a maximum of 15 seconds away (or less if the
> retry_interval is lower).
> Thoughts?
I can't help but think that something like this could have been quite
easily resolved with a round-robin scheduling queue, where items requested
to be queued would simply get inserted within 5 seconds of the requested
time where there are the most free slots. The prng idea will probably
work just as well though, and I'm fairly certain you could just use
next_time = service->check_interval - 7 + (*service->description & 0xf);
to get a distribution almost equally good without having to bother
about the PRNG-business. This would yield 7 seconds +-, which is
probably good enough.
OP5 AB www.op5.se
on peace.
