I was recently installing and configuring Nagios 1.0 and I came across
an idea. If this has been tried already, my apologies. I did actually
read the documentation
My goal is to be able to set a variable that can be used in a service
definition. I think of the templates as macros, and I want to be able
to reuse service definitions. I think the best way to describe this is
code examples, so here goes
command_name check_http_regex
command_line $USER1$/check_http -H $HOSTADDRESS -p $ARG1$ -u
$ARG2$ -w 3 -c 7 -r $ARG3$
# Using the port number as ARG1, the relative URL as ARG2, and the regex
# to check for as ARG3.
name WEBSERVICE
service_description Webserver REGEX Check
check_command check_http_regex!$port$!$url$!$regex$
register 0
use default_settings
# Here begins the REAL service definition
name webserver
service_description Generic Website
port 8080
url /test/index.php
regex 'teststring'
use WEBSERVICE
This would make my configuration easier to read as well as add new
entries. I would not have to redefine the check_command every time and
the args would be plainer (I wouldn't have to look so deeply when I come
back in 6 months to remember what each arg does).
Is this possible now? If not, would it be easy to add?
Thanks in advance,
-BAK
Ben Klang, KF4WBX
Unix Administrator
[email protected]
