[Nagios-devel] [PATCH 3/3] Fix submitting service commands
--------------030406090508040603050300
Content-Type: text/plain; charset=ISO-8859-15; format=flowed
The big patch that reworked how command submission works
apparently broke service command submission. This patch
fixes that, and also adds the proper format attributes to
cmd_submitf() so that it won't happen again (well, assuming
one remembers to manually run the compiler with warnings
enabled anyways).
Original patch by Badri Pillai
I just added the gcc __attribute__() stuff to cmd_submitf()
to prevent this to happening for other commands as well.
Signed-off-by: Andreas Ericsson
cgi/cmd.c | 3 ++-
1 files changed, 2 insertions(+), 1 deletions(-)
Content-Type: text/x-patch;
name="a34628b78ea053e0c6d486ff7e05b47dad7f943d.diff"
Content-Disposition: inline;
filename="a34628b78ea053e0c6d486ff7e05b47dad7f943d.diff"
diff --git a/cgi/cmd.c b/cgi/cmd.c
index 89cb216..dadbf08 100644
--- a/cgi/cmd.c
+++ b/cgi/cmd.c
@@ -1900,6 +1900,7 @@ void commit_command_data(int cmd){
return;
+__attribute__((format(printf, 2, 3)))
static int cmd_submitf(int id, const char *fmt, ...)
char cmd[MAX_EXTERNAL_COMMAND_LENGTH];
@@ -2030,7 +2031,7 @@ int commit_command(int cmd){
break;
case CMD_ADD_SVC_COMMENT:
- result = cmd_submitf(cmd,"%s;%s;%d;%s;%s",current_time,host_name,service_desc,persistent_comment,comment_author,comment_data);
+ result = cmd_submitf(cmd,"%s;%s;%d;%s;%s",host_name,service_desc,persistent_comment,comment_author,comment_data);
break;
case CMD_DEL_HOST_COMMENT:
--------------030406090508040603050300--
