>I've just ran into a interesting problem with my nagios 3.1.0 code.
>Intro:
>Take a host with two differenct contactgroups assigned.
>One of those cg should notify during daylight (tp-definition:
>0800-1700 for example)
>and the other contactgroup with one contact member for only non
daylight notifications (tp: 1700-2400,0000-0800).
>Nagios is sending out a notification to all possible contacts, ignoring
the notification_period of the contact.
>I've already double checked the configs (regarding objects.cache as a
result of all possible template resolutions).
>Possible needed config snipplet at the bottom of this message.
We are experiencing the same thing with 3.0.6. I'm running Nagios on a
RHEL 5 box, I've not made any changes to the settings used by the
compiler they are default (I'm not smart enough to mess with that).
If you guys get a fix or work around please make sure to post it, as we
are interested in the conclusion of this issue.=20
Thanks a bunch,=20
-greg
