Re: [Nagios-devel] cfg_dir recursion not working
Dr. Dave Blunt wrote:
> I have an install with a number of Nagios configs files stored under
> subdirectories:
> /usr/local/nagios/etc/rps//acfgfile
> /usr/local/nagios/etc/rps//anothercfgfile
> /usr/local/nagios/etc/rps//yetanothercfgfile
I suppose the files all match the glob(3) pattern
/usr/local/nagios/etc/rps/*/*.cfg
Otherwise, that's possibly the issue right there.
> There are no valid cfg files in /usr/local/nagios/etc/rps. All services and
> hosts are defined in the cfg files under , , etc.
> When I define:
> cfg_dir=/usr/local/nagios/etc/rps
> in nagios.cfg the preflight check comes back with errors saying it can't
> find any hosts or services.
Are you running this on a Solaris or AIX platform? I think recursion
only works on system that has the header file, and that one
isn't present on all unices.
OP5 AB www.op5.se
Lead Developer
