[Nagios-devel] [patch] Re: flap detection + state retention
--mP3DRpeJDSE+ciuQ
Content-Disposition: inline
On Jan 24 15:17, Tom Throckmorton wrote:
> *delurks*
> Hello all,
> Can someone here please verify that in Nagios 2.x the state of flap_detection
> should or shouldn't be persistent across a reload / restart?
> See my post below, and the brief thread on nagios-users:
> http://thread.gmane.org/gmane.network.nagios.user/52044
> Tests on 2.x seem to show that the retained values for global/host/service flap
> detection aren't being honored on a reload. This seems to contradict the docs,
> so I'm thinking it's a bug.
So, it looks as if the calls for modified_attributes were completely missing
from the flapping routines, and appear to have been so since the inception of
2.x. As i'm reading the code, these calls flag the attributes as modified,
which means they'll be considered later in the state retention code. Without
the calls, the state retention code ignores these attributes, which leads to
the problem.
Please consider the attached patch against base/flapping.c - this is against
2.10, which happens to be the same as CVS. I'd appreciate it if someone with a
better handle on the code (and better programming skills) would have a look to
make sure I'm not doing something dumb.
I've tested this on 2.10 running on CentOS 5, and it appears to do the right
thing regarding retaining state across reloads.
Cheers,
-tt
Tom Throckmorton
OIT - CSI
Duke University
--mP3DRpeJDSE+ciuQ
Content-Disposition: attachment; filename="nagios-flapping.patch"
--- base/flapping.c.dist 2006-05-19 10:25:03.000000000 -0400
+++ base/flapping.c 2008-01-25 09:15:41.000000000 -0500
@@ -41,6 +41,8 @@
extern double low_host_flap_threshold;
extern double high_host_flap_threshold;
+extern unsigned long modified_host_process_attributes;
+extern unsigned long modified_service_process_attributes;
/******************** FLAP DETECTION FUNCTIONS ********************/
@@ -457,6 +459,10 @@
printf("enable_flap_detection() start\n");
#endif
+ /* set the attribute modified flag */
+ modified_host_process_attributes|=MODATTR_FLAP_DETECTION_ENABLED;
+ modified_service_process_attributes|=MODATTR_FLAP_DETECTION_ENABLED;
/* set flap detection flag */
enable_flap_detection=TRUE;
@@ -479,6 +485,11 @@
printf("disable_flap_detection() start\n");
#endif
enable_flap_detection=FALSE;
@@ -502,6 +513,9 @@
printf("enable_host_flap_detection() start\n");
#endif
+ hst->modified_attributes|=MODATTR_FLAP_DETECTION_ENABLED;
/* nothing to do... */
if(hst->flap_detection_enabled==TRUE)
return;
@@ -536,6 +550,9 @@
printf("disable_host_flap_detection() start\n");
#endif
if(hst->flap_detection_enabled==FALSE)
return;
@@ -586,6 +603,9 @@
printf("enable_service_flap_detection() start\n");
#endif
+ svc->modified_attributes|=MODATTR_FLAP_DETECTION_ENABLED;
if(svc->flap_detection_enabled==TRUE)
return;
@@ -620,6 +640,9 @@
printf("disable_service_flap_detection() start\n");
#endif
if(svc->flap_detection_enabled==FALSE)
return;
@@ -660,9 +683,3 @@
return;
--mP3DRpeJDSE+ciuQ--
