On 03/23/2010 03:02 PM, Samuel Mutel wrote:
> Hello,
> I want to add in objects.h a field to service_struct so I put after "int
> last_state;"
> int last_state_before_flapping;
> For the moment, I just put this line. When I compil Nagios and after a
> notification, the process crash with Program received signal SIGSEGV,
> Segmentation fault.
> Do you have an idea ?
If you're using any kind of eventbroker module that access raw service
objects, they will need to be re-compiled or Nagios will crash.
If you're re-building without making sure all sources that use the
objects.h header file is recompiled (not just re-linked), you'll get
a crash.
Other than that, I really can't think of anything.
OP5 AB www.op5.se
on peace.
