Re: [Nagios-devel] Help! I have tons of orphans!
I just turned it on. I should know in about an hour if it works or not.
Geoff
On Tuesday 11 March 2003 11:12, Jeremy T. Bouse wrote:
> Have you tried turning on the obsess over services option and
> see if the problem presists? I've found some better performance with
> heavy testing with this option enabled...
> =09Jeremy
> On Tue, Mar 11, 2003 at 10:40:34AM -0600, Geoff Lovett wrote:
> > I am currently upgrading from Netsaint 0.0.7 to Nagios 1.0, and I
> > am finding that after Nagios runs for an hour or so, lots of
> > services start getting orphaned. The resources on this box aren't
> > exhausted at all (that I can tell). It tried lowering the
> > max_concurrent_checks from 306 to 200, which helped for a little
> > while. Now it's exhibiting the same behaviour.
> > The specs for the box are Debian Linux, kernel 2.4.20, PIII 650, 250M=
=2E
> > I don't go into swap and the load generally stays between 1 and 5. =
I
> > am montoring 620 services on 95 boxes.
> > While the services are getting orphaned, the load is pretty low
> > (around 1.2). The check latency average shoots way up to 46, and the
> > max to 111.
> > Another thing I've noticed is that though the max_concurrent_checks i=
s
> > set to 200, the number of processes named "nagios" is greater than
> > that during the periods when it reports orphans.
> > Has anyone else experienced this? I searched the FAQ and this mailin=
g
> > list, and didn't find anything.
> > Please copy my address in replies as I am not currently subscribed.
> > Thanks,
> > Geoff
> > This SF.net email is sponsored by:Crypto Challenge is now open!
> > Get cracking and register here for some mind boggling fun and
> > the chance of winning an Apple iPod:
> > http://ads.sourceforge.net/cgi-bin/redi ... thaw0031en
> > _______________________________________________
> > Nagios-devel mailing list
> > [email protected]
> > https://lists.sourceforge.net/lists/lis ... gios-devel
