--0-463975317-1188480805=:26382
Content-Type: text/plain; charset=iso-8859-1
Content-Transfer-Encoding: 8bit
Hi Guys,
I need to monitor cisco switches and routers physical port status.Can i use check_ifoperstatus plugin or not.One more question my switch port is having 25 or 50 ports how do i check the status.This plugin check all interfaces by default or i have to menction each interface.
Thanks for your help
Best Regards
Once upon a time there was 1 GB storage in your inbox. Click here for happy ending.
Content-Type: text/html; charset=iso-8859-1
Hi Guys, I need to monitor cisco switches and routers physical port status.Can i use check_ifoperstatus plugin or not.One more question my switch port is having 25 or 50 ports how do i check the status.This plugin check all interfaces by default or i have to menction each interface. Thanks for your help Best Regards
--0-463975317-1188480805=:26382--
