Arno Lehmann wrote:
> Hello,
> On 7/6/2006 11:34 AM, Romain Le Merlus wrote:
>> -Nagios 3.x will allow for user-specified custom variables in
>> -host/service/contact definitions. That means that you'll be
>> -able to add
>> -your own "criticality" variable and access its value in macros. For
>> -example, to define a variable called "criticality", you'll prepend it
>> -with an underscore as follows...
>> Good morning Ethan,
>> Do you already list the differents variables levels for this feature ?
> I doubt that, because these variables are *user-specified*. It's up to
> you how to use them.
As Arno indicated, the custom variables are user-defined, so I'll just
be documenting how to go about adding them to various object
definitions. The naming of the custom variables are up to the user.
Ethan Galstad,
Nagios Developer
Email: [email protected]
