--------------080804030906090108020700
if there wasn't an actual check, and the wait time was below the
required, an update should not be done. this is what is indicated by
comments, but doesn't seem to be done in the implementation. please see
if the attached diff is valid. thanks.
Content-Type: text/x-patch;
name="hostflapping.diff"
Content-Disposition: inline;
filename="hostflapping.diff"
--- base/flapping.c 2008-11-30 19:22:58.000000000 +0200
+++ /tmp/flapping.c 2009-02-28 16:48:40.000000000 +0200
@@ -223,8 +223,10 @@
/* if we didn't have an actual check, only update if we've waited long enough */
- if(update_history==TRUE && actual_check==FALSE && (current_time-hst->last_state_history_update)last_state_history_update)state_history[(hst->state_history_index==0)?MAX_STATE_HISTORY_ENTRIES-1:hst->state_history_index-1];
@@ -234,7 +236,7 @@
if(last_state_history_value==hst->current_state)
return;
#endif
+#endif
/* what thresholds should we use (global or host-specific)? */
low_threshold=(hst->low_flap_thresholdlow_flap_threshold;
--------------080804030906090108020700--
