On Thu, Oct 14, 2010 at 10:56:56AM +0200, Andreas Ericsson wrote:
> On Wed, Oct 13, 2010 at 9:47 PM, Marcel J.E. Mol wrote=
> > Hello,
> > My first post to the list... I just started playing with nagios and d=
oing
> > some test developments. For this I need the location of the directory
> > where all config files reside. I noticed that all config files are de=
fined
> > with absolute paths and the config directory itself is not defined.
> > It like to suggest a change to location.h.in so I can define new conf=
ig
> > files within a single source file without needing to update other nag=
ios
> > core files. =C2=A0The patch is attached. It just adds a DEFAULT_CONFI=
G_DIR
> > define to location.h.in.
>=20
> The default value for that macro would cause Nagios to recursively sear=
ch
> all of /etc for files ending with .cfg.
I think you mistake this with the runtime definition with of cfg_dir in
nagios.cfg.
The suggested define in location.in.h is only a compile time
definition. It allows me to create new source files, say myproject.c
and in it do something like
fp =3D open(DEFAULT_CONFIG_DIR "myproject.cfg");
without tampering other nagios source files while being flexible at where
the config files reside. In the current situation I need to create a
file that is processed by the configure step to set the correct place
for config files.
> Try the cfg_dir option in nagios.cfg instead. It should do roughly what=
you
> want.
So it has nothing to do with cfg_dir...
-Marcel
--=20
=3D=3D=3D=3D=3D=3D-------- Marcel J.E. Mol ME=
SA Consulting B.V.
=3D=3D=3D=3D=3D=3D=3D--------- ph. +31-(0)6-54724868 =
P.O. Box 112
=3D=3D=3D=3D=3D=3D=3D--------- [email protected] =
2630 AC Nootdorp
__=3D=3D=3D=3D www.mesa.nl ---____U_n_i_x______I_n_t_e_r_n_e_t____ The Ne=
therlands ____
They couldn't think of a number, Linux user 1148 -- counter.=
li.org
so they gave me a name! -- Rupert Hine -- www.ruperthine.com
