Ethan Galstad wrote:
> Andreas -
> Did you have any luck(?) in having this happen again, so as to be
> able to track it down?
It's been happening with irregular interval ever since. Always with the
same backtrace, but not always on friday nights any more.
Here's how it's compiled;
CFLAGS="-pipe -march=i386 -mcpu=i686 -O2 -momit-leaf-frame-pointer
-mpreferred-stack-boundary=3 -ggdb3 -g"
export CFLAGS
./configure --prefix=/opt/monitor --disable-statuswrl
--with-nagios-user=monitor --with-nagios-group=httpd --disable-event-broker
Notable is that the customers to which this has happened are running
lots of custom plugins and I'm not sure whether those kill themselves in
a timely manner or not. A few other customers also do this, but they
don't seem to be affected at all. All other software is identical on all
systems.
I'll send a patch to allow coredumps in a clean way.
Cheers.
> On 20 Dec 2004 at 11:40, Andreas Ericsson wrote:
>>gdb nagios core
>>(gdb) bt
>>#0 0x00000000 in ?? ()
>>#1 0x001c100b in __libc_malloc (bytes=512) at malloc.c 2695
>>#2 0x08060971 in service_result_worker_thread(arg=0x0) at utils.c:4666
>>#3 0x00162de2 in pthread_start_thread(arg=0xbf5ffe40) at manager.c:241
>>#4 0x0020f70a in thread_start () from /lib/libc.so.6
>>(gdb)
>>What strikes me as weird is the fact that this crash happened after
>>Nagios had been running for 4 days (and always seems to happen at
>>friday nights between 9 PM and 11:30 PM in this particular network). I
>>would have expected service_result_worker_thread() to fail at
>>start-time, if at all.
>>Mind though, I've made some modifications to allow it to dump core
>>(which should be either default, ./configure-able or a command
>>argument since debugging without it is not nearly as efficient, and
>>"ulimit c none" can be used to prevent it from doing so any way), but
>>only very minor such that shouldn't affect stability at all.
OP5 AB www.op5.se
Lead Developer
