Ethan Galstad wrote:
> Andreas Ericsson wrote:
>> So, I started looking into revamping the event queue logic, but ended up
>> with a migraine from the cumbersome way logging is done, so I decided to
>> try doing something about it, and the attached 3-patch series is the
>> result from it.
>> It compiles alright, both for nagios and the cgi's. I haven't done much
>> in the way of checking past that though, so testing would be welcome.
>> Given that the patches don't change much in the way of logic, they
>> shouldn't really affect anything in significant way.
> [snip]
> Thanks for the patches - they are excellent ideas. I'll get them
> implemented when I get back to the US later this week.
Before I forget.. Any chance you could implement them verbatim one by
one first and then commit whatever changes you feel prudent on top of
the last one? The messages on top of the patches (past the mail-headers)
should make decent commit-messages.
I've got some more work in the queue, and it would help me port those
changes over to whatever the new cvs head turns out to be without
any manual work if any fixups (such as renaming the logit() function)
are committed later.
OP5 AB www.op5.se
