[Nagios-devel] Problem compiling Nagios with mysql support on
------=_NextPart_000_0044_01C49753.1D9CEDC0
Content-Type: text/plain;
charset="us-ascii"
Ldconfig is supposed to pick up the path from /etc/ld.so.conf. Sometimes it
does and sometimes it doesn't.
Try setting
export LDFLAGS="-L /usr/local/mysql/lib"
I've never figured out why ldconfig doesn't pick up the mysql path..
- Harper
Harper Mann
Groundwork Open Source Solutions
510-599-2075 (cell)
_____
[mailto:[email protected]] On Behalf Of Winkles,
William (Bill)
Sent: Friday, September 10, 2004 3:30 PM
To: Kemp, Darren; [email protected]
Subject: RE: [Nagios-devel] Problem compiling Nagios with mysql support on
Solaris 9
Darren,
I am exporting LD_LIBRARY_PATH=/usr/local/lib:/usr/local/mysql/lib:/usr/lib,
but still having the problem.
Any other suggestions?
Thanks.
Bill
_____
Sent: Friday, September 10, 2004 2:53 PM
To: [email protected]
Solaris 9
Make sure LD knows where your sql libs are.
-dkk
_____
William (Bill)
Sent: Friday, September 10, 2004 4:37 PM
Subject: [Nagios-devel] Problem compiling Nagios with mysql support on
Solaris 9
All,
I am trying to compile Nagios 1.2 with mysql support on a Solaris 9 box and
keep getting the following error:
ld: fatal: Symbol referencing errors. No output written to nagios
collect2: ld returned 1 exit status
Nagios compiles fine if I don't use mysql.
I am using the following to configure Nagios:
./configure --with-mysql-xdata --with-mysql-inc=/usr/local/mysql/include
--with-mysql-lib=/usr/local/mysql/lib
No errors on the configure, just when I make.
Any suggestions on what I need to do to resolve this issue? I'm using mysql
V 4.0.21. I included the complete make output below.
Thanks.
Bill
Bill Winkles
Lucent Technologies *
Sr. Technical Engineer
Global Network Operations Center - Denver
* +1 720/482-6528 (Voice)
* +1 303/941-2455 (Mobile)
# make all
cd ./base && make
make[1]: Entering directory `/billy/nagios/nagios-1.2/base'
gcc -g -O2 -I/usr/local/mysql/include -DHAVE_CONFIG_H -DNSCORE
-L/usr/local/mysq
l/lib -lmysqlclient nagios.c checks.o config.o commands.o flapping.o
logging.o
notifications.o sehandlers.o utils.o sretention.o ../xdata/xrddb.c
../common/com
ments.c ../xdata/xcddb.c ../common/objects.c ../xdata/xodtemplate.c
../common/st
atusdata.c ../xdata/xsddb.c perfdata.o ../xdata/xpddefault.c
../common/downtime.
c ../xdata/xdddb.c -lm -o nagios
Undefined first referenced
symbol in file
mysql_fetch_row /var/tmp//cceGv5Hq.o
mysql_query /var/tmp//cceGv5Hq.o
mysql_errno /var/tmp//ccDJD4XD.o
mysql_close /var/tmp//cceGv5Hq.o
mysql_insert_id /var/tmp//ccQzsQ08.o
mysql_free_result /var/tmp//cceGv5Hq.o
mysql_store_result /var/tmp//cceGv5Hq.o
mysql_init /var/tmp//cceGv5Hq.o
mysql_real_connect /var/tmp//cceGv5Hq.o
make[1]: *** [nagios] Error 1
make[1]: Leaving directory `/billy/nagios/nagios-1.2/base'
make: *** [all] Error 2
Content-Type: text/html;
charset="us-ascii"
<html xmlns:v=3D"urn:schemas-microsoft-com:vml" =
xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns:st1=3D"urn:schemas-microsoft-com:office:smarttags" =
xmlns=
...[email truncated]...
