Re: [Nagios-devel] check_by_ssh plugin error
On Tue, 2002-11-19 at 17:15, Russell Scibetti wrote:
> I know this is more of a nagiosplug issue, but I know most people are
> also on this list, so:
> There is a bug in the CVS version of check_by_ssh. When you use "-t #"
> to set a timeout, you get a segmentation fault and core dump. But when
> you use "--timeout=#" it works fine. This was under Linux RedHat 7.2
> (checked from the command line).
Thanks for the bug report.
Should be fixed now (in CVS).
Karl DeBisschop
