Re: [Nagios-devel] [PATCH] dkhash: memory leak and possible loss of
Nice catch. I'll remove the unrelated changes and apply.
Thanks.
On 02/20/2013 05:48 PM, [email protected] wrote:
> From: Max Sikström
> Pointer to previous in dkhash_remove was only set for first element in a given
> bucket. So when finding for example third object for removal, setting
> prev->next=obj->next looses the reference to the old prev->next, which is the
> second object in the list.
> This can be tested by creating a hash map of one bucket (practically a linked
> list), and fill and remove all, both forward and backward.
> Signed-off-by: Max Sikström
> lib/dkhash.c | 5 ++---
> lib/test-dkhash.c | 36 +++++++++++++++++++++++++++++++++++-
> 2 files changed, 37 insertions(+), 4 deletions(-)
> diff --git a/lib/dkhash.c b/lib/dkhash.c
> index cab3d66..74a9a76 100644
> --- a/lib/dkhash.c
> +++ b/lib/dkhash.c
> @@ -209,9 +209,7 @@ void *dkhash_remove(dkhash_table *t, const char *k1, const char *k2)
> prev = bkt; /* pay attention */
> for (; bkt; bkt = bkt->next) {
> - if (strcmp(k1, bkt->key))
> - continue;
> - if ((!k2 && !bkt->key2) || !strcmp(k2, bkt->key2)) {
> + if (!strcmp(k1, bkt->key) && ((!k2 && !bkt->key2) || !strcmp(k2, bkt->key2)) ) {
> if (prev == bkt) {
> /* first entry deleted */
> t->buckets[slot] = bkt->next;
> @@ -223,6 +221,7 @@ void *dkhash_remove(dkhash_table *t, const char *k1, const char *k2)
> t->removed++;
> return dkhash_destroy_bucket(bkt);
> + prev = bkt;
> return NULL;
> diff --git a/lib/test-dkhash.c b/lib/test-dkhash.c
> index 02accba..313b361 100644
> --- a/lib/test-dkhash.c
> +++ b/lib/test-dkhash.c
> @@ -87,10 +87,13 @@ static int del_matching(void *data)
> int main(int argc, char **argv)
> dkhash_table *tx, *t;
> - unsigned int x;
> + int x;
> struct test_data s;
> char *p1, *p2;
> + char *strs[10];
> + char tmp[32];
> t_set_colors(0);
> t_start("dkhash basic test");
> t = dkhash_create(512);
> @@ -143,6 +146,37 @@ int main(int argc, char **argv)
> test(0 == dkhash_num_entries(tx), "x table post all ops");
> test(0 == dkhash_check_table(tx), "x table consistency post all ops");
> dkhash_debug_table(tx, 0);
> + t_end();
> + for(x=0;x + sprintf(tmp, "string %d", x);
> + strs[x] = strdup(tmp);
> + t_start("dkhash single bucket add remove forward");
> + t = dkhash_create(1);
> + for(x=0;x + dkhash_insert( t, strs[x], NULL, strs[x] );
> + for(x=0;x + p1 = strs[x];
> + p2 = dkhash_remove( t, p1, NULL );
> + test( p1 == p2, "remove should return a value" );
> + t_end();
> + t_start("dkhash single bucket add remove backward");
> + for(x=9;x>=0;x--) {
> + p1 = strs[x];
> return t_end();
OP5 AB www.op5.se
on peace.
