Re: [Nagios-devel] NDO increase nagios_servicechecks/output size
Michael Streb wrote:
> Hi Ethan,
> Hi list,
> recently went into problems with the "output" field in the
> nagios_servicechecks table so i had a deeper look and it turned out that the
> field size is set to "varchar(255)" only, i think this should be increased
> to something like "varchar(4096)" to make use of the longer serviceoutput in
> nagios3x.
> I don`t know right now if 4k is the maximum serviceoutput in 3x.
It's not, as it's dynamically allocated. 255 is the maximum size for varchar
in databases though. Anything larger than that has to be stored as "TEXT"
or "BLOB" objects, which means a fairly serious hit to performance (as all
those objects get stored in one or more separate files on disk).
OP5 AB www.op5.se
