Re: [Nagios-devel] regarding upcoming features
Ideally, if the config stuff is stored in a database, everyone would be
happy!
1. external CGI's could pull in data quickly and efficiently.
2. The ability to expand to multiple "display applications" is
exteremely easy. I for one am working on a much cleaner
PHP interface to replace the CGI's
3. The ability to modify the configuration on the fly is almost
automatically available. Plus the ability to
Easly also have third party applications modify the configurations is
also intrinsic.
-Mark
P.S. oh, one other poptions that I've been toying around with is by
simply having a shared library that
Returns configuration information, makes it tremendously more expandable
while still having the control over
The configuration files.
-----Original Message-----
[mailto:[email protected]] On Behalf Of Subhendu
Ghosh
Sent: Wednesday, October 16, 2002 10:07 PM
To: [email protected]
Subject: Re: [Nagios-devel] regarding upcoming features
On Wed, 16 Oct 2002, Ethan Galstad wrote:
> On 16 Oct 2002 at 10:28, Subhendu Ghosh wrote:
> > I was going thru the upcoming features list and had a
> > couple of questions/comments.
> I just made a few updated to the page, as it hadn't been changed in a
> long time...
> > CGI:
> > Even if the move to Fast CGIs is made, having the CGIs read the
> > object
> > config files directly would still cause the CGIs to be out of sync
with
> > the running monitor if the monitor was not restarted.
> > Perhaps a "compiled" config created at the the start by the
> > monitoring
> > daemon would prevent the out of sync issue.
> Rather than creating a different format for a compiled config file,
> I'll just have the daemon write a single cache file containing all
> object definitions (in raw template format). The CGIs will then be
> able to read that instead of the normal config files. A compiled
> config file would probably be faster than the template-based ones,
> but using FastCGI should nullify that issue.
cache/compile - I guess we both mean the same thing.
> > Adaptive monitoring:
> > Also if adaptive monitoring get used - some way to write out the
> > running
> > config would be useful. Otherwise a restart would loose the any
changes
> > made. Of course the argument could be made that one must modify the
> > configs as well.
> Yep, the format of the retention file (and status log, for that
> matter) will be updated to contain current and normal settings for
> anything that can be changed on-the-fly.
Well if you allow hosts and services to be added on-the-fly then we
might
obviate the need for config files for some situations!
but small steps first :)
-sg
This sf.net email is sponsored by: viaVerio will pay you up to
$1,000 for every account that you consolidate with us.
http://ad.doubleclick.net/clk;4749864;7604308;v?
http://www.viaverio.com/consolidator/osdn.cfm
_______________________________________________
Nagios-devel mailing list
[email protected]
https://lists.sourceforge.net/lists/lis ... gios-devel
