Re: [Nagios-devel] cfg_dir and hidden directories
* Mark Plaksin [2006-04-19 07:53]:
> a change between 2.0b4 and 2.1 is causing Nagios' cfg_dir processing to
> recurse into hidden directories. It *looks* like the problem is in the
> diff between version 1.99 and version 1.100 of xdata/xodtemplate.c but I
> can't put my finger on the exact cause.
Are you _sure_ you see the duplicate definitions due to Nagios recursing
into hidden subdirectories? I cannot reproduce this with Nagios 2.1/2.2
and from reading the code, I don't see how the check for hidden
directories in xdata/xodtemplate.c:430 could fail.
If you're running Nagios on Linux, could you check the output of "strace
nagios -v /path/to/nagios.cfg" and see whether Nagios really open(2)s a
file within a hidden directory?
> If I build 2.1 with version 1.99 of xodtemplate.c the problem is gone.
The fact that it "works" with this revision of xodtemplate.c doesn't
properly isolate the problem, as the handling of "non-*.cfg" files and
directories within a cfg_dir is somewhat undefined with rev. 1.99[*].
Holger
[*] http://thread.gmane.org/gmane.network.nagios.devel/2172
PGP fingerprint: F1F0 9071 8084 A426 DD59 9839 59D3 F3A1 B8B5 D3DE
