Re: [Nagios-devel] Nagios ePN and perl modules
Hash: SHA1
I tracked down the problem. It was caused by the check_ntp script after I put
in the
use lib utils.pm;
like you suggested. So far the only thing that has worked for me is to hard
code the path into it. Maybe this will just get changed when a user compiles
the nagios-plugins?
- -Doug
On Thursday 02 May 2002 15:02, Douglas E. Warner wrote:
> It looks like it worked. I'm getting the following error from some plugin
> right now:
> BEGIN not safe after errors--compilation aborted at (eval 29) line 75.
> but I'm still debugging that. The FindBin::Bin patch worked under
> mini_epn; maybe that needs re-written so its more in-line with how Nagios
> is running code. sigh.
> -Doug
Douglas E. Warner Network Engineer
CTI/PAdotNET http://www.pa.net +1 717 503 9006
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.0.6 (GNU/Linux)
Comment: For info see http://www.gnupg.org
iD8DBQE80aCIJV36su0A0xIRArRPAKCHDsw0XmhpuRWtQXbIVsew9kkHswCeIDAJ
Qg/t/RDB7mNTnLSMvD1rDSU=
=zdmP
-----END PGP SIGNATURE-----
