[Nagios-devel] SEGV in 2.0b1 (tarball from Nagios.ORG) - at exit(result): FreeBSD 4.9-RELEASE/pthread lib.
This is a multi-part message in MIME format...
------------=_1105175507-4941-107
Content-Disposition: inline
Dear Folks,
This thread can be put to sleep: the SEGV of 2.0b1 with embedded Perl
was nothing to do with Nagios
(or threaded Perls or FreeBSD: Nagios was torpedoed by a SEGV from
Perl trying to run a C function that was linked with a different version
of Perl, a known problem with Perl extensions [they simply must be
rebuilt to run against a different version of Perl]).
It's too early for me to say how 2.0b1 goes with embedded Perl in a
small site (196 hosts/405 services), but it seems Ok so far (in
foreground mode with test 1 -eq 1 as the notify command).
Yours sincerely.
Stanley Hopcroft
IP Australia
Ph: (02) 6283 3189 Fax: (02) 6281 1353
PO Box 200 Woden ACT 2606
http://www.ipaustralia.gov.au
Content-Type: text/plain; name="disclaimer.txt"
Content-Disposition: inline; filename="disclaimer.txt"
MIME-Version: 1.0
X-Mailer: MIME-tools 5.415 (Entity 5.415)
This message contains privileged and confidential information only
for use by the intended recipient. If you are not the intended
recipient of this message, you must not disseminate, copy or use
it in any manner. If you have received this message in error,
please advise the sender by reply e-mail. Please ensure all
e-mail attachments are scanned for viruses prior to opening or
using.
------------=_1105175507-4941-107--
