------_=_NextPart_001_01C6372C.B13F1933
Content-Type: text/plain;
charset="us-ascii"
Alessandro,
=20
I'm using Nagios 2.0 - NDOMOD 1.2.=20
=20
If I read this correctly, the object_id connects all the appropriate
tables to names, etc.
=20
The ndo_hosts table has no IP information, nor does it have an ID for
the hostgroup_name. I would suspect for the hostgroup_name information
it should also have "hostgroup_id", but it is not there either.
=20
At this point I wonder if it would be better to try to use the
"built-in" database functionality, rather than NDO until NDO is more
firm.=20
=20
All I need is host status information, and from what I can tell that
information is available with the built-in functionality.
=20
Thanks in advance,
=20
Mike
=20
=20
In the table creation script I have the following:
=20
CREATE TABLE IF NOT EXISTS `ndo_hosts` (
`host_id` int(11) NOT NULL auto_increment,
`instance_id` smallint(6) NOT NULL default '0',
`config_type` smallint(6) NOT NULL default '0',
`host_object_id` int(11) NOT NULL default '0',
`check_command_object_id` int(11) NOT NULL default '0',
`check_command_args` varchar(255) NOT NULL default '',
`eventhandler_command_object_id` int(11) NOT NULL default '0',
`eventhandler_command_args` varchar(255) NOT NULL default '',
`notification_timeperiod_object_id` int(11) NOT NULL default '0',
`check_timeperiod_object_id` int(11) NOT NULL default '0',
`failure_prediction_options` varchar(64) NOT NULL default '',
`check_interval` smallint(6) NOT NULL default '0',
`max_check_attempts` smallint(6) NOT NULL default '0',
`notification_interval` smallint(6) NOT NULL default '0',
`notify_on_down` smallint(6) NOT NULL default '0',
`notify_on_unreachable` smallint(6) NOT NULL default '0',
`notify_on_recovery` smallint(6) NOT NULL default '0',
`notify_on_flapping` smallint(6) NOT NULL default '0',
`stalk_on_up` smallint(6) NOT NULL default '0',
`stalk_on_down` smallint(6) NOT NULL default '0',
`stalk_on_unreachable` smallint(6) NOT NULL default '0',
`flap_detection_enabled` smallint(6) NOT NULL default '0',
`low_flap_threshold` double NOT NULL default '0',
`high_flap_threshold` double NOT NULL default '0',
`process_performance_data` smallint(6) NOT NULL default '0',
`freshness_checks_enabled` smallint(6) NOT NULL default '0',
`freshness_threshold` smallint(6) NOT NULL default '0',
`passive_checks_enabled` smallint(6) NOT NULL default '0',
`event_handler_enabled` smallint(6) NOT NULL default '0',
`active_checks_enabled` smallint(6) NOT NULL default '0',
`retain_status_information` smallint(6) NOT NULL default '0',
`retain_nonstatus_information` smallint(6) NOT NULL default '0',
`notifications_enabled` smallint(6) NOT NULL default '0',
`obsess_over_host` smallint(6) NOT NULL default '0',
`failure_prediction_enabled` smallint(6) NOT NULL default '0',
PRIMARY KEY (`host_id`),
UNIQUE KEY `instance_id`
(`instance_id`,`config_type`,`host_object_id`)
) ENGINE=3DMyISAM DEFAULT CHARSET=3Dascii COMMENT=3D'Host definitions';
=20
-----Original Message-----
Sent: Tuesday, February 21, 2006 12:40 PM
To: Mike Koponick
Cc: [email protected]
Subject: Re: [Nagios-devel] MySQL Mapping - NDO
=20
The ndo_hosts has the address as far as I know, in version 1.3, it
does't have the hostname. The hostname is in ndo_objects table and its
referenced by the field host_object_id
. in the field name1.
The field objecttype_id
<https://192.168.10.30/phpMyAdmin/sql.ph ... =3D1&coll=
ati
on_connection=3Dutf8_general_ci&db=3Dnagios&table=3Dndo_objects&pos=3D0&s=
ession_
...[email truncated]...
Original poster: lessandro Ren [mailto:[email protected]]=2
