Re: [Nagios-devel] Nagios Core 3.5.0rc1
Thank, Phil. I found my logic error and corrected it.
On 3/8/13 2:49 PM, Randal, Phil wrote:
> Hi Eric,
> I’ve double checked my configs against the base 3.5.0rc1 cgi.cfg and nagios.cfg, nothing in them to cause a problem (except I made sure cgi.cfg had
> escape_html_tags=0
> What’s happening is that the double quote character in a href="www.dell.com ..." is being escaped into &#34
> Even if it was correct to escape it at that point, there's a bug (no semicolon at end of string, e.g. &h34;)
> Patch to fix that issue:
> diff -Naur cgiutils.c.old cgiutils.c
> --- cgiutils.c.old 2013-03-08 20:14:51.000000000 +0000
> +++ cgiutils.c 2013-03-08 20:16:17.000000000 +0000
> @@ -1055,7 +1055,7 @@
> /* for simplicity, all other chars represented by their numeric value */
> else {
> - sprintf( temp_expansion, "&#%u", *( unsigned int *)inwcp);
> + sprintf( temp_expansion, "&#%u;", *( unsigned int *)inwcp);
> if((( outstp - encoded_html_string) + strlen( temp_expansion)) output_max) {
> strncpy( outstp, temp_expansion, strlen( temp_expansion));
> @@ -1154,7 +1154,7 @@
> /* Encode everything else (this may be excessive) */
> else {
> - sprintf( temp_expansion, "&#%u", ( unsigned int)wctemp[ 0]);
> + sprintf( temp_expansion, "&#%u;", ( unsigned int)wctemp[ 0]);
> if((( stp - encoded_html_string) + strlen( temp_expansion)) output_max) {
> strncpy( stp, temp_expansion, strlen( temp_expansion));
> Even with that issue fixed firefox and IE mishandle urls of form
> href="http://www.dell.com/support/troubleshoo ... ag=xxxxxxx"
> It expects
> which is the original plugin output.
> status.cgi in 3.4.4 didn't escape the double quote character, which is the difference between the working 3.4.4 and broken 3.5.0rc1
> CentOS 5.9, Apache httpd-2.2.3-76.el5.centos
> Cheers,
> Phil
> From: Eric Stanley [mailto:[email protected]]
> Sent: 08 March 2013 17:27
> To: Nagios Developers List
> Subject: Re: [Nagios-devel] Nagios Core 3.5.0rc1
> Sorry, Phil, but I'm still not able to reproduce it. I tried using the check_esxi_hardware.py plugin and I get the following displayed in the 'Status Information' column on the status.cgi:
> OK - Server: Dell Inc. PowerEdge T710 s/n: xxxxxxxx System BIOS: 6.0.7 2011-08-18
> Can you send the applicable configs?
> Thanks,
> Eric
> On 3/7/13 6:48 AM, Randal, Phil wrote:
> ./check_openmanage -H hc-server -I
> OK - System: 'PowerEdge 1955', SN: 'xxxxxxx', 16 GB ram (8 dimms), 1 logical drives, 2 physical drives
> The href lines are what are getting mangled (appended in quotes) to the base cgi url
> Both 3.4.4 and 3.4.5rc1 work fine.
> It's my own rpm build, but that shouldn't make any difference.
> Cheers,
> Phil
> -----Original Message-----
> Sent: 07 March 2013 12:03
> To: [email protected]
> Thanks for the report, Phil.
> I'm having a hard time guessing what might have broken that between
> 3.4.4 and now. I did a quick test using check_dummy and I don't see the issue.
> Are you running 3.4.4? If not, what version are you running where it works correctly
...[email truncated]...
