Re: [Nagios-devel] Nagios sometimes shows wrong status
Hi!
> Whilst I'm not sure it has anything to do with your issue, nagios
> executes scripts without an environment defined (usually), which means
> just calling "grep" will not find the path. You should define full
> path to executables whenever possible. Of course, you said "relevant
> part of the script" which could imply you've defined the path earlier
> on.
> Definetly an odd outcome. What about dumping the content of the
> metastat calls, and the variables you've assigned? That way you can
> see what nagios is actually seeing. ie:
> echo "====" >> /tmp/svm.debug
> datum=`date`
> META=`/usr/sbin/metastat`
> echo ${datum} ${META} >> /tmp/svm.debug
> MAINTCNT="`/usr/sbin/metastat |grep -i maint |wc -l`"
> RESYNCNT="`/usr/sbin/metastat |grep -i resync |wc -l`"
> echo ${datum} ${MAINTCNT} >> /tmp/svm.debug
> echo ${datum} ${RESYNCNT} >> /tmp/svm.debug
> [.. rest of script ..]
ok, i've changed the script:
datum=`/usr/bin/date`
#META=`/usr/sbin/metastat`
META=`/usr/bin/cat /export/home/nagios/metastat.out`
MAINTCNT="`/usr/bin/cat /export/home/nagios/metastat.out | /usr/bin/grep
-i maint | /usr/bin/wc -l`"
RESYNCNT="`/usr/sbin/metastat | /usr/bin/grep -i resync | /usr/bin/wc -l`"
NOTOK=0
status=$STATE_UNKNOWN
if [ $RESYNCNT -gt 0 ]; then
NOTOK=1
TEXT="WARNING - One or more disks are in resync state."
status=$STATE_WARNING
fi
if [ $MAINTCNT -gt 0 ]; then
NOTOK=1
TEXT="CRITICAL - One or more disks are in maintenance state."
status=$STATE_CRITICAL
fi
if [ $NOTOK -eq 1 ]; then
echo $TEXT
datum=`date`
echo $datum $status >> /tmp/svm.debug
exit $status
fi
echo "OK - There is no maintenance necessary!"
exit $STATE_OK
i've dumped the metastat output to a file before the disk has been
replaced...
/export/home/nagios/metastat.out:
d31: Mirror
Submirror 0: d41
State: Okay
Submirror 1: d51
State: Okay
Pass: 1
Read option: roundrobin (default)
Write option: parallel (default)
Size: 58542696 blocks (27 GB)
d41: Submirror of d31
State: Okay
Stripe 0:
Device Start Block Dbase State Reloc Hot Spare
c1t1d0s1 0 No Okay Yes
d51: Submirror of d31
State: Okay
Stripe 0:
c1t3d0s1 0 No Okay Yes
d30: Mirror
Submirror 0: d40
State: Okay
Submirror 1: d50
State: Okay
Pass: 1
Size: 12584484 blocks (6.0 GB)
d40: Submirror of d30
State: Okay
Stripe 0:
c1t1d0s0 0 No Okay Yes
d50: Submirror of d30
State: Okay
Stripe 0:
c1t3d0s0 0 No Okay Yes
d7: Mirror
Submirror 0: d17
State: Needs maintenance
Submirror 1: d27
State: Okay
Pass: 1
Size: 41679603 blocks (19 GB)
d17: Submirror of d7
State: Unavailable
Stripe 0:
c1t0d0s7 0 No - Yes
d27: Submirror of d7
State: Okay
Stripe 0:
c1t2d0s7 0 No Okay Yes
d3: Mirror
Submirror 0: d13
Submirror 1: d23
State: Okay
Pass: 1
d13: Submirror of d3
State: Unavailable
Stripe 0:
c1t0d0s3 0 No - Yes
d23: Submirror of d3
State: Okay
St
...[email truncated]...
