[Nagios-devel] ndoutils help.
------_=_NextPart_001_01C630D1.FC45C7EF
Content-Type: text/plain;
charset="us-ascii"
Alessandro,
=20
Make sure you also have the following running:
=20
/usr/local/nagios/bin/ndo2db -c /usr/local/nagios/etc/ndo2db.cfg
=20
(your directory structure may vary)
=20
Also, you have want to send a tail of your /var/log/messages (If you are
sending to syslog) just to make sure you are seeing the module is being
initialized and connecting to the SQL server.
=20
I have been using NDO for quite a while and don't have any issues. I do
need to upgrade to the stable release of software this week, but
currently I'm using 2.0rc.
=20
Mike
=20
-----Original Message-----
[mailto:[email protected]] On Behalf Of
Alessandro Ren
Sent: Monday, February 13, 2006 12:11 PM
To: [email protected]
Subject: [Nagios-devel] ndoutils help.
=20
=20
i've been trying to use ndoutils and I can no get nagios to dump
anything. The broker gets loaded and logs in nagios.log that has been
loaded, and either dumping in file or to a unix socket, I dont get
anything.
I've made some changes on the code to dump all logs to mysql by
myself already, but I'd like to use ndoutils, as they dump more
information and it'd be more complience for futures upgrades.
I am using nagios-2.0 stable release and tried ndoutis-1.2 and
ndoutils-1.3, the broker_module entry is in the nagios.cfg, it creates
de file ndo.dat and writes the start informantion but does't dump
anything.
Thanks. =20
=20
--=20
__________________________________________________
Alessandro Ren
OpServices
Luciana de Abreu, 471 - Sala 403
Porto Alegre, RS - CEP 90570-060
=20
* phone 55(51)3061-3588
* fax 55(51)3061-3588
* mobile 55(51)8151-8212
* email [email protected]
=20
Content-Type: text/html;
charset="us-ascii"
OpSign
Alessandro,
Make sure you also have the =
following
running:
<p cla
...[email truncated]...
