Re: [Nagios-devel] Performance values, what to use? (Was: Documentation
Karl, I have re-posted to [email protected] for some
fuller discussion.
I do have one comment. Sending a string as a metric value is not
something the protocol supports. I also believe the aim of this
protocol is to storing numerical performance data. Which can be
imported to PP or RRD. I am not sure that passing a string is a good
idea. No plugin currently does this. Can you explain further why you
would want to pass a string as a performance value?
Regards, Ben.
Karl DeBisschop wrote:
> Ben Clewett wrote:
>> All systems have to use the same format, as specified in the
>> documentation:
>> http://nagiosplug.sourceforge.net/devel ... tml#AEN185
>> Unfortunately there are holes in this documentation. I have also seen
>> requests to amend this documentation to add more features, and patch
>> up the holes.
> I have somehow missed these discussions.
>> Which have been, for what ever reason, ignored by these news groups.
>> I would personally like to see NULL, -INF and +INF supported as
>> possible values. Which PP and RRD can use in their own ways. :)
> I do not remember seeing any concrete proposals to that effect. But I
> would generally support the addition of token to represent these values.
> Bear in mind that perfdata is not always numeric - it may be a string
> value. So what ever means are used to encode a token for the above cases
> must be distinquishable from a text value of (say) NULL that a moniroed
> application might return.
