Switch_router
Switch_router
I am getting alot of errors since I upgrade. Check attachment
tonyyarusso
Re: Switch_router
You only have two actual errors, which are due to using a comma in a service_description. The warnings are okay to ignore if you want, or you can use a template to assign the timeperiod you want to all of them.
Re: Switch_router
I just finished configuring two routers, however, i got some errors. WHy am I getting this out of sync? i was getting them before the upgrade.
Re: Switch_router
This issue is reflecting the same problem as the "Sorry Dave" error. There is a difference in either your server time or your timezone settings are off in the php.ini file.
http://support.nagios.com/wiki/index.ph ... e.22_Error
