Ben wrote:
> A quick glance at the code makes it look like all the xodtemplate
> functions spend most of their time list walking. Converting from a list to
> a tree/hash should dramatically speed things up.
Forget hashes. If objects were properly indexed in internal tables, this
would be a much simpler issue where only host-names have to be hashed.
Services could then be organized in a 3D table indexed by size_t
host_id, which would reside in the host object struct (in running
config, that is). The one-time load penalty would be slightly higher,
but not necessarily very much since the internal tables really don't
have to bother with alphabetical sorting and such.
If one wants it even faster, it would be simple to put all objects
referenced by others into such tables. For instance, a service object
could have a serviceextinfo_id variable so as to quickly locate it in a
map. With only very minor modifications to the CGI's and the daemon
(printing total number of each object type at the top of objects.cache
so it doesn't have to bother with reading, counting, allocating,
indexing and tabulating in separate passes), one would notice a
tremendous speedup.
> On Tue, 8 Feb 2005, Jason Martin wrote:
>>I'm looking ahead to running a 6K host / 60K service distributed
>>Nagios setup reporting up to a central Nagios host.
>>The test procedure was to write a config file consisting of X
>>hosts with 10 services per host.
>>On a 2 proc 2Ghz Intel machine, the preflight time for 1.1 and
>>2.0cvs comes out as:
>>Hosts v1.1(s) v2.0(s)
>>100 0 1
>>400 5 4
>>500 7 6
>>1000 23 23
>>2000 149 117
>>3000 321 251
>>4000 526 431
>>5000 760 651
>>6000 1034 912
>>The profile for the preflight is:
>>Each sample counts as 0.01 seconds.
>> % cumulative self self total
>> time seconds seconds calls ms/call ms/call name
>> 84.24 4.33 4.33 5502 0.79 0.79 xodtemplate_find_service
>> 7.78 4.73 0.40 1 400.00 449.66 xodtemplate_sort_services
>> 4.09 4.94 0.21 1 210.00 210.00 pre_flight_check
>> 0.78 4.98 0.04 5501 0.01 0.01 find_service
>>It looks like xodtemplate_find_service is still taking up a log of time. Can
>>anything be done to speed it up? Otherwise it looks like 6K hosts is going to be unatainable.
>>Thanks,
>>-Jason Martin
>>This message is PGP/MIME signed.
> SF email is sponsored by - The IT Product Guide
> Read honest & candid reviews on hundreds of IT Products from real users.
> Discover which products truly live up to the hype. Start reading now.
> http://ads.osdn.com/?ad_id=6595&alloc_id=14396&op=click
> Nagios-devel mailing list
> [email protected]
OP5 AB www.op5.se
Lead Developer
