[Nagios-devel] Distributing plugins
Hi list,
I often write new plugins, and I face a distribution problem: how to
distribute them without having to scp and editing nrpe.cfg on each server?
Few headscratchings later, I came with a couple of solutions:
- using automatic copies from a repository to the clients (rsync or
equivalent)
Pros: simple. Cons: implies an extra protocol, which may not be desirable
- using NFS: clients mount the plugins directory from the repository
Pros: simpler. Cons: implies NFS, which may not be desirable
- modifying nrpe to distribute the plugins on demand. The Nagios server
could hold the plugins repository, and send the ones missing to the client.
A timestamp checking should also be needed to distribute new versions.
Pros: no extra protocol. Cons: needs some development, may introduce a lag
on the first service call.
Going further, nrpe could also maintain the nrpe.cfg file. Why keeping the
"command[..]" statements locally? They could be sent via nrpe itself.
And a couple of beers ahead, the repository might even be a database.
I know this changes the philosophy behind nrpe quite a bit, but it may worth
to think about.
Comments needed please.
Francois
_________________________________________________________________
À faire rêver : des endroits célèbres à voir
http://search.live.com/images/results.a ... ORM=SERNEP
