Re: [Nagios-devel] not possible to disable checks?
thank you so much! the freshness-checking was enabled by the underlying
template... hmpf...
now the checks are executed no more when aktive checks are disabled.
greetz + thanx, thomas.
-----Urspr=FCngliche Nachricht-----
Von: Jason Martin [mailto:[email protected]]=20
Gesendet: Mittwoch, 20. Oktober 2004 16:45
An: [email protected]
Betreff: Re: [Nagios-devel] not possible to disable checks?
On Wed, Oct 20, 2004 at 01:10:13PM +0200, [email protected] =
wrote:
> When I disable all service checks some of them are really disabled,=20
> and some others are not. I see no differences between the checks =
which=20
> could be resp. for this behavior.
I believe checks that are forced because of freshness-checking are =
exempt
from the 'disable service checks' action. Do any of your checks have
'check_freshness 1' defined?
-Jason Martin
--=20
I'm a nobody, nobody is perfect, therefore I'm perfect.
This message is PGP/MIME signed.
