Hash: SHA1
Tested against 2.7 and latest CVS: When I define a template like this:
define servicedependency {
dependent_hostgroup_name hsgrp_1,hsgrp_2,hsgrp_x
name template_name
register 0
Nagios bails out with the following error:
Error: Could not expand master hostgroups and/or hosts specified in
service dependency (config file '/path/to/config', starting on line 88)
Looking quickly at the code it seems that it could affect many other
objects... I didn't have time to pinpoint the problem though. I can
possibly take a deeper look tonight if it's not obvious to anyone more
used to play with the template code.
As a workaround I can define a host_name and override it in the service
definition.
You may ask why I have a so simple template definition? The answer is
that I keep all hostgroup lists at the same place and grouped together,
so that when I add/remove hostgroups I don't need to grep around the
config to make sure I didn't miss something. (While we're at it, I'm
just thinking that the ability to get a hosts list out of a service
templates would be nice if it can be done in a sane way...)
Thomas
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.7 (MingW32)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFHOfzw6dZ+Kt5BchYRAt10AKC0AjImevWweeXAcVJxBGe3H51X7ACg3u8I
elzX6DmaT5Umyd9veWYWQOA=
=K7AC
-----END PGP SIGNATURE-----
