Mark Eisenblaetter wrote:
> On Jan 16, 2008 10:38 AM, Mark Eisenblaetter
> wrote:
>> Hi,
>> On Jan 16, 2008 10:07 AM, Andreas Ericsson wrote:
>>> Please don't top-post. It makes it hard to follow the discussion,
>>> especially when you're top-posting to an answer that wasn't top-
>>> posted. Anyways...
>>>> Hi,
>>>> sorry for the latye replay,
>>>> Then I will have to much templates, because i will need for every
>>>> kombination of args a new template.
>>>> For example by check_http I will need a template vor every
>>> website/service i
>>>> want to check or for every disk with diffrend warning and Critival
>>>> threshosld.
>>>> Thats not so practicable.
>>> Originally you wrote:
>>>>>> so it would be great if i can say in the template use the
>>> check_command
>>>>>> (check_dummy) defined in the template and not that defined in the
>>> Host.
>>> To which I replied:
>>>>> That's what not setting anything in the object itself is for. If you
>>> don't
>>>>> have a check_command in the host object, it will use the one from the
>>>>> template.
>>> In other words, if you want a particular object to inherit the value
>>> from
>>> the template, simply don't set that value in the object. There was no
>>> other question-like statement in your original mail.
>> Ok, then my first mail was not so clear I hoped.
>> I was thinking of that as a new feature, to minimize the templatework.
> Ok it seems that i am the only one that would like this feature.
> Or do i miss one way to handle that situation without having a template for
> nearly every check?
You still have not clarified your original email. Only discovered that it's
not clear enough. If you can manage that, I'm sure there's already a solution
in Nagios for you.
OP5 AB www.op5.se
